Hello william_antonelli
Yes, you can change where the sync codes are but be very careful. 90% of our sync codes come out from the same spot in the post. This minimizes any error of the sync codes getting out of sync. In the case of this post you would look to move the variable setting and the Procedure call.
The harder ones to deal with are usually in M2 and S2 modes when pinch turning.
Sync codes typically happen when the Mode changes, or a Tool post changes in the same mode.
The first thing though to do is make sure you don't have any errors at the process table. Any error is a potential to have sync codes come out wrong.
Can you give me an example of the unnecessary sync codes?
Bill Cain
Sr. Technical Consultant
