04-24-2017
05:52 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-24-2017
05:52 AM
Hi @hx,
Thank you for contacting Autodesk support.
Once you have completed your Add-In, you can add the .dll macro into FeatureCAM by using the following procedure...
1. Navigate to the Add-Ins tab
2. Select Manage...
3. Select the yellow folder icon and browse to the dll you have made and press OK
4. Ensure that the line item is ticked before pressing OK again
5. You should now be able to run the macro.
To run your macro, you may need to create a button in the ribbon to run your macro.
Alternatively, you can select Run Basic Macro... and select the your dll.
If you are happy with this solution, please press Accept as Solution.
If you need any further assistance, please reply to this message and I will be happy to help.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
