mrsipping
541 Vistas, 4 Respuestas
Advice for PC configuration to use for FutureCam
Hi everyone, sorry if this question may be off topic however I wanted some advice on what configuration to use for FutureCam. I saw the recommended features and I was wondering if a radeon pro or a geforceRTX would also work as a video card, do you have any advice for me? Do you know any laptops to recommend for FutureCam? Thanks to those who will help me
s.fenchel6NSF2
en respuesta a: mrsipping
I'm running FeatureCAM2024 on a laptop with these specs:
  • Windows11 Pro
  • Intel Core i9-13900HX
  • Geforce RTX 4050 6GB GDDR6
  • 32GB DDR5-4800
  • Corsair MP600 Pro NH 1TB
I think it's a bit overkill for FCAM, but I'm running a lot of more power-demanding software on this thing, as well.
The laptop was around 2000€.
FCAM is running very smooth on this.
Hope this helps.
mrsipping
en respuesta a: s.fenchel6NSF2
Okay I thank you, so do you think anyway with an i7 an rtx 3xxx series and less ram can run smoothly? With an i5 processor how do you see it? Too little core power? thank you very much for your help
s.fenchel6NSF2
I just checked the laptop I previously used (until November last year).
That one had these specs:
  • Windows 10 Pro
  • Intel Core i7-8750H
  • Geforce GTX 1050
  • 16GB RAM
  • 500GB SSD
I only ran FCAM 2022 on this but never had any problems with performance. Can't attest to the newer version, though.
As for the i5, I have no idea if it's powerful enough to run it.
But from all the software I use, I think FCAM is one of the least demanding.
Other than during the long 3D simulation and big 5-axis toolpath computing it never stressed my system much.
bmarkeyJ44PH
At work I run an i5 with some  some low end nvidia card, ( i don't recall offhand).  At home, an older i7 with an RTX 3060.
NIGHT AND DAY.  Any 3d simulation at work is painful.  If there is surface milling, yeh go get coffee and take your time.  At home, trivial.
Visually the 3060 makes it much easier to see things, especially in wireframe view.
Long story short, I do a lot of the more intensive things at home, its just less painful for me at the end of the day.
It seems that the more GPU you throw at it the better it is to use.
