- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Ok, I can order new tooling yes, I was trying to use what was already ordered by someone else. I think I was more confused as to why a tapered endmill with a more acute angle wouldn't be able to mill this since there would be clearance, as you'd use a radius tool to do a draft angle.
Full disclosure, this is the first time I've used tapered endmills with FC, and I really just assumed there was some setting I was missing.
I can get it to work if I do each side independently and just constrain its stock, though that seems like the long way around. Plus I had to force it to finish decently with z increment, as I think that "Radius tool scallop height" under finish is ignored by the tapered endmill. I have to do some more testing to see if that holds up.
Either way, I'd still be curious to know the acute angle part of it.
Thank you.
Bruce
