01-04-2024
07:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-04-2024
07:46 AM
Unable to mill tapered pocket(groove?), never finishes to bottom.
Trying to mill a long groove with a 15 degree taper on each side, and a small radii at the bottom. We seem to be getting the same issue no matter how we try to do it. It will rough to a certain point with a flat em, then stop, which makes sense. It will attempt to finish with the taper but it never goes full depth.
I'm guessing it has to do with doing it as two sides? I would have assumed a final pass down the center since the taper mill has the same end radius.
The best luck so far has been with draft angles as seen in the attached doc. I have a solid model but surface milling makes a total bodge of it, plus the run time exponentially longer.
Is there a better way to do a feature like this?
Bruce
