rmtmtg01e17c352k
378 Vistas, 1 Respuesta
Code NC problem
When I click on the NC code key I get this:   "CNC file D:\Programmi\Autodesk\FeatureCAM
2023\Posts\Mill\3-axis\Fanuc 3x Mill Default.cnc non esiste. Impostarlo prima dal menu Lavorazione/Post processor."
What can I do?
Hi @rmtmtg01e17c352k
it means that FeatureCAM is unable to find the post in the designated location.
Which for a normal installation is problematic, as some samples posts should be installed by default with FeatureCAM, so either you have moved, or deleted some elements in the installation folder.
If you have another post or know the location of another post, you can try to select another cnc file (this is the extension for FeatureCAM post).
To select a post, click on the name.cnc in the status bar, it will open a file browse dialog for selecting the post.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
