- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When i try to save some models in Part Library, it makes additional Setup Stream for the model.
How could it be avoid ?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I don't know if my suggestion adds something to your needs, but I don't use part library anymore.
Instead, I created a program with all my template operations and then I copy paste them to the program I am creating.
Sometimes I paste the entire operation and then change the curves, and others I create a new operation and just paste the atributes from my template.
I just find it easier to manage when I need to change something in the templates.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi.
This part of FeatureCAM is a little old-school. The problem is your decimal point in the feature name. Some characters will create this situation, and starting an entity name with a numeral will do the same thing. I would suggest replacing the decimal with an underscore - and always begin the name with a letter.
I hope this helps!
Chris Cole
Senior Solutions Engineer
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That is what works for me. Like you said, start with a letter and have nothing else but letters, numbers and underscores. Make sure that there are no spaces between them.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks a lot for your answers.
Finally i found a reason, why FeatureCAM saves this feature as a stream.
The process operation of entire feature was selected as "between 2 curves". That's why those two curves came together with a feature in part library as a stream.
