- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
hi all :
how to get the operation max depth value?
look pic , operation list is show each operation information. the depth value is not match (7.664mm), the Correct depth value is 42.336mm. i use FMOperation.Depth & FMOPeration.DepthText can not get the correct value. Is there a solution to the problem? thx!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello @nicholas_wu
This is because you are confusing two values.
7.6 is really the depth of the hole, i.e the distance from the top of the "cylinder" to the bottom.
Whereas 42.... is the coordinate of the hole bottom.
Two different concepts, so two different values.
So, you may need to use the GetFeatureLocation to grab the Z value, then substract the depth value to it.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your advice!!
I need the current toolpath(operation) max depth not the hole feature max depth! the bottom of the
hole feature to the zero position is 42, but i set the machine depth is 40, use GetFeatureLocation is not easy the calculate!
