05-11-2022
06:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-11-2022
06:56 AM
You can fill the area using Surface edges to create a curve and then try a Cap surface. You can't untrim a imported model since there is no data on the previous state of the model for featurecam to reference. If Cap doesn't work you can try from surface region using the same curves.
EDIT: It looks like you might be using a stock model, switch to a standard block and just check and see if its just no seeing enough material there to generate a tool path.
