04-28-2022
05:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-28-2022
05:20 AM
Hi, Max.
Here are a couple things you can look at:
First, make sure the G98/G99 codes are entered into the post. In Xbuild, go to CNC Info > NC Codes and make sure they are there.
Next, make sure you are using "Combine similar holes into canned cycle" in the Strategy tab of the feature. If that's a setting you want all the time, make sure it is enabled on the Drilling tab of your Machining Attributes/Configurations.
That should do it. I hope that helps.
Chris Cole
Senior Solutions Engineer
