- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My post doesn't ouput G98/99 even if <CYCLE-RTRCT> is in my post. It leaves a blank space on my G-code line.
When I post with a generic Fanuc post, I do have the G98/99 in my G-code.
It seems like something else is blocking it.
Does someone have a idea?
Thanks!
Max
¡Resuelto! Ir a solución.
- Etiquetas relacionadas:
4 axis
drilling
Fanuc
Fanuc Post
Post Processors editing
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi, Max.
Here are a couple things you can look at:
First, make sure the G98/G99 codes are entered into the post. In Xbuild, go to CNC Info > NC Codes and make sure they are there.
Next, make sure you are using "Combine similar holes into canned cycle" in the Strategy tab of the feature. If that's a setting you want all the time, make sure it is enabled on the Drilling tab of your Machining Attributes/Configurations.
That should do it. I hope that helps.
Chris Cole
Senior Solutions Engineer
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Chris,
My G codes in Xbuild are defined and my strategy is the same as on your screen shot.
As you can see on my screen shot, I'm posting a blank space where I want my G99. My other posts are fine but this one doesn't cooperate!
Thanks!
Max
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hey, Max.
If you don't mind, attach your post, and I will test it on my end.
Chris
Chris Cole
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sorry Max, but not seeing an attachment on this end.
Chris
Chris Cole
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
sorry, the forum does not support .CNC
with file in txt format
(just rewrite cnc as extension)
thanks,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Still not coming through, so why don't you just email it to me. chris.cole@autodesk.com
Chris Cole
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I rewrote my post, testing each modification instead of batching them.
I found that it's glitching when I move the command before
the command.
I usually program: G99 G81 ... It seems that I have to output: G81 G99 ...
I didn't test yet. I hope the machine's gonna be happy with it!
thanks!
Max
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have the same problem.
CYCLE-RTRCT don't work with turning features but only with mill features, so if the turning hole is the first operation the value of CYCLE-RTRCT is a space.
I forced the value of CYCLE-RTRCT at the beginning with: "[:<CYCLE-RTRCT> = "G98"]".
