dmealer
317 Vistas, 2 Respuestas
Post processor support
Is there any help available for post processor adjustments in partmaker?
ChrisDPCnc
en respuesta a: dmealer
There is probably some AD partner that will charge you for the pleasure....
Many changes can be done yourself, the post is fairly easy to follow if you have read the help files.
Or ask away and the community can probably help you out too
christopher_marion
en respuesta a: ChrisDPCnc
Hi @dmealer
Exactly what @ChrisDPCnc said.  You can try and tackle this yourself, but if you are not confident and want to make sure this is implemented correctly, I suggest you reach out to a partner for this.
To look for an accredited partner in your location, look in the Autodesk Services Marketplace site and change the filter to suit your local.
Christopher Marion
Autodesk Canada
