b.harp275SC
240 Vistas, 1 Respuesta
PART MAKER PINCH TURN ROUGH ONLY
Hello All,
Part Maker 2018 mill turn environment,
I am trying to pinch turn a part and I am able to get the rough and finish tool to run together but I am not able to make multiple depth of cut passes with just a rough pinch turn and then just a finish pinch turn. When I run the rough and finish tool together for the pinch turn it only pinches and finishes the first cut then stops pinch turning and only runs the rough tool on turret 1. Any help would be greatly appreciated.
ChrisDPCnc
en respuesta a: b.harp275SC
You will need to do the roughing as a separate operation.
The logic for pinch means that both tools have to work together from start to finish of the toolpath.
