arossiFREQJ
250 Vistas, 1 Respuesta
ID Threading on turned part.
 I'm trying to do an internal thread on a turned part. Having a hard time getting it oriented properly. I'm using a side cutter on a bar. I can only get it to cut facing the face of part, not inside diameter. Thank you for any help.
Pictures posted below.
Erick-Pires
en respuesta a: arossiFREQJ
Hello arossiFREQJ , how are you ?
Maybe this is happening due to the alignment of your machining.
I'm attaching some images hope it helps you. If not , could you send the project to better evaluate what is happening ?
Sincerely, Erick Pires
