ChristopherMarion
en respuesta a: JHearons
Hi @JHearons
If I remember correctly, the "lock operation" that is found in the hidden menu in FeatureCAM just protects the overridden tool selection from reverting back to the default tool.  This isn't anything that affects the simulation.
The only option is exactly what you described.  You need to save the 3d simulation with the option "save results as starting point" to avoid replaying toolpaths that have already been verified.
Hope this helps!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
