cr-cam01
354 Vistas, 2 Respuestas
head orientation
Good morning,
I would need to lock the b axis every 5 degrees (and positive and negative multiples)
with the m107 function and leave it unlocked in the other cases. who can help me insert the correct wording in the post? thank you
gregorANU4T
en respuesta a: cr-cam01
You can use the modulo operator to determine if the rotary value is a multiple of 5, for example:
<IF>[eq(<ROT2-WIND>%5,0)]<THEN>M107<ENDIF>
cr-cam01
thanks gregorANU4T
in fact the proposed solution works ...
in the meantime I also found a solution with the string:
[: W = <ROT1-WIND> / 5] <IFNOT> [(W% 1 == 0)] <THEN>
Thanks again
