Ian_GB
503 Vistas, 4 Respuestas
HAAS VF 4th axis post.
Hi, would really appreciate it if anyone could provide a HAAS VF 4th axis post. cheers.
ChristopherMarion
en respuesta a: Ian_GB
Hi @Ian_GB
The older versions of FeatureCAM (Pre 2017) had some 4th axis Haas posts.
I've attached one here.
Hope this gets you started.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Ian_GB
en respuesta a: ChristopherMarion
Thank you so much, I only had one from our feature cam 2009 disc. Our uk Autodesk reseller insisted on an extra £600/$800 dollars for the post even though we are on an maintance contract and have been on a contract with them for 14 years.
ChristopherMarion
Hi @Ian_GB
I as well work for a reseller in Canada.
Your reseller is correct in charging for a post.  The only reason I gave you this one is because it used to be included with the install.  Keep in mind, any changes will most likely incur service charges.  I as well would have to charge services for modifying this post.
Please do continue to work with your resellers with items like post builds, post modifications and software implementations.  Resellers do guarantee their work, so if things do need correction, we will work directly with you to get the job done right to your satisfaction.
Cheers,
Christopher Marion
SolidCAD - Canada
Ian_GB
##- thank you for the this information and thanks again for the post. Much appreciated. -##
Get Outlook for Android
