- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @shawn6R83D
I agree. My suggestion is for you to report it directly to Autodesk development. This forum is a community thing and Autodesk employees are not mandated to use it for items like this.
The best way to express this it through an Autodesk support case. If you are on maintenance, you can do this through your account.
To do this, log into your Account. Then:
- Once you are logged in, press the black question mark at the bottom right of the screen
- Choose the option Post Purchase Support
- Then, choose Help Using My Software
- Choose FeatureCAM Products from the dropdown
- Place a reason as to why you need help. Put in something like "Issue with 3d simulation"
- Once you press the search, there will be some general help articles, but you will want to press the "All other customers" at the bottom of the page.
Once you get to that point, just fill in all of the information about what you are experiencing with FeatureCAM. That should generate a case number and you will get a response that someone will contact you. You should get contacted in a day or so.
They should then create an internal task to development, since it does look to be a bug with the software.
Hope this helps. If you have any more questions regarding this, let me know and I'll do my best to help.
Technical Specialist - CAM
SolidCAD - Canada
