ChristopherMarion
en respuesta a: shawn6R83D
Hi @shawn6R83D
I've struggled to understand this same issue in the past.  The only sense I can make out of it, is that you can only view the spindle and the holder in simulation if you use one that has been defined with parameters.  If you try and use a custom shaped holder (by curve or solid), then the spindle does not show.
Pretty sure I reported this in the past already to development.
To get around this, you could just model a spindle on the back of your holders as part of the solid or curve.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
