ChristopherMarion
en respuesta a: kgueorguiev
Hi @kgueorguiev
I think the porblem is not with the selected surf mill operation, but with one of the options that is turned on.
Take a look at this image.....  Even though the option for Interleave Spiral Paths appears to be off, it looks like it is still on which would cause your issue.
To get around this, just create a new process (Z level) to unset everything.  Then apply the boundaries and step downs and everything else you were using.  I did this quickly on your part and it behaved how you'd expect it to.  I wouldn't change to a different strategy since I would have selected Z level as well.
FeatureCAM just looks to be holding onto that option and will not release it for whatever reason.  Just create a new one to move past it.
Hope this helps.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
