- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm trying to program my HAAS SL-10 lathe using FeatureCAM but when i try and simulate the code on the lathe it gives me an error saying it hasn't been given the feed rate. when looking at the g-code its right and will either skip the feed rate or say "F0." as the feed rate. I've tried looking in the post editor but i can't find what to change to fix the problem.
Am I doing something wrong while programming or is it a problem with the post processor?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I beleive that the.FM file you uploaded is the temp file? It is only 1k in size.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The word formatting is not setup for less than 1.
Go into the post > cnc info > word formatting > find feed/rev > click the underlined text > change the metric format from 4.0 to 4.4, this will give you 4 places after the decimal. Your feed for min is setup the same if you want to change that just edit that word the same as the other.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
