299 Vistas, 1 Respuesta
Licence problems
Hi
We have 2 user licences for Featurecam Premium.
If we have user “MazakI400” running 1 licence on 1 PC and then try to start Featurecam on a different PC with user “OliverW” it will not start with error message “No licence available”.
If however this user “OliverW” then logs out and then logs back in as different user “Lathe6” on the same PC, Featurecam will start and run correctly.
If no users are running Featurecam then user “OliverW” can run Featurecam with no issues, however the other user on “MazakI400” gets the licence error message and cannot run even though we have 2 licences.
Again if user “OliverW” logs out and then in as another user he can also use Featurecam and so can the “MazakI400” this time.
Have you had any similar occurrences from other users and if so is there a fix.
Pete Young
en respuesta a: Anonymous
Are your licenses shared over your network or are they installed locally on each machine?
