ChristopherMarion
en respuesta a: Anonymous
Hi @Anonymous
Up until FeatureCAM 2017, all versions of the software relied on a dongle key for licensing.  With this dongle, there are two components, a physical USB key (which you have) and a license file that normally resides in one of two locations:
  1. C:\Program Files\Common Files\Delcam
  2. C:\dcam\config\pass
I normally told our customers to put it in the 2nd location.  It's the more common of the two spots.
Now, I am assuming this is a new PC you are installing the software, you can take that file from another computer and place it here and the software should work.
Here is an article on how to install paf license files
Lastly, if you cannot find the license file or it is unrecoverable, you will need to create a support case directly with Autodesk.  Autodesk stopped supported these license types years ago, so it may not be entirely possible.
Hope this helps!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
