04-15-2021
02:17 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-15-2021
02:17 PM
Hi @Anonymous
His may be hard to diagnose here in this forum.
On thought is, your ini has been corrupted. You can check by closing FeatureCAM and navigating to C:\ProgramData\FeatureCAM
Then remove the ezfm_ui.ini (put it on your desktop). Restart FeatureCAM and see how this goes.
This can also be a graphics card issue. Make sure you are using your dedicated graphics hardware instead of your onboard graphics card. In FeatureCAM go into the settings and make sure this option is checked.
If this doesn't work, I suggest to reach out to your local reseller. If you are on maintenance still, you have been pushed to an Autodesk partner for this type of support.
Hope this helps!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
SolidCAD - Canada
