- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Forgive me for the newbie question, I am new to Partmaker. I am trying to get the Z axis to retract at the end of the turning when transitioning to the drills. The current code is calling up the drills, and then moving to Z-.05. I need to have the Z-.05 at the end of the turning operation (or any immediately prior operation), to avoid the drill moving into center and crashing into the material. I am not sure if this needs to be done in a programming window or a post modification. Thank you in advance for any help!
Chris
President
Swissomation, Inc
Micro Machining
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Chris,
To create a retract move at the end of a turning operation all you need to do is set a cutting point. By setting the Pz value to -.050, your last point for that operation will occur at that Z-.050 location. Otherwise, your lead in/lead out will determine the first and last point of a turning operation.
Christian Poluch
Applications Engineer
