bhorstTGM48
469 Vistas, 2 Respuestas
Tool Holders
I want to get a tool holder from my main tool crib and add it to the tool crib that is saved with my current .fm document. I this possible? This is a milling document.
kelbie.ockey
en respuesta a: bhorstTGM48
Funny enough, I've never had someone ask about this.
The easiest way is to just go to the tool manager, select export, and uncheck everything but the Tool Holders options, and then import into the desired crib.
There may be another way, but that was the quickest option I could come up with. LMK if that doesn't work.
Kelbie Ockey
Sr. Implementation Consultant
gregorANU4T
When you're in the tool dialog to select a tool, just select your other tool crib from the popup menu on the status bar, select the tool you want to use, then change back again from the popup menu. The tool you selected will stay selected, even though it's not in the current crib.
