hx
351 Vistas, 1 Respuesta
Import model using exchange at the API
I write an UDF to import and dgk file.
I use the code
Dim modelDoc As FMDocument = fc.Documents.AddFM(tagFMSetupType.eST_Milling, False)
If modelExtension.ToLower = ".x_t" Then
  modelDoc.SilentImport(project.ModelFilename)
Else
  modelDoc.ImportUsingExchange2(project.ModelFilename, True)
End If
Now the FeatureCAM imprt an model and pop-up dialogue box
How can I use the api method to select the "Accept the imported data 'as is' and exit the wizard"
spencer.hardcastle
en respuesta a: hx
Hi @hx,
Thanks for posting in the FeatureCAM Forum.
As far as I know, you can't currently use "ImportUsingExchange2" in silent mode and there isn't an alternative method.
Have you managed to find/use a workaround for this?
I will report this as a new feature request for you and include your details in the request.
Spencer Hardcastle
Manager of Customer Advocacy - Autodesk Fusion
