TomOliver
490 Vistas, 3 Respuestas
Print file with white background in 2021
Is the option to print with white background gone in update 2021?
File > Print. Does not bring up the traditional Featurecam print dialogue box.
I've attached what my box looks like.
Featurecam 2021.0.0.0052
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
ChristopherMarion
en respuesta a: TomOliver
Hi @TomOliver
If you go to FILE>PRINT in 2021, do you not see this?
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
TomOliver
en respuesta a: ChristopherMarion
My screen file dropdown doesn't look that. It did before I updated but when I updated it change back.
Autocad LT
FeatureCam Ultimate
Fusion 360
ChristopherMarion
Hi @TomOliver
You have disabled the ribbon interface.  The only way to do that is to open FeatureCAM's hidden menu.
Press the CTRL + RMB on the status bar at the bottom of the interface.  That will pop up the following menu.
Then turn on Show ribbon
That should fix you up.
Christopher Marion
SolidCAD - Canada
