brian_p1
en respuesta a: walter.schaefer
@walter.schaefer, thank you for you reply, I would like to be able to have what ever text is entered in the post variable tab to be written into the program, your code will only add probe top to the program as it is hard coded into the post eg if 1234 was written into the tab then 1234 would be output in the program or if abcd was written into the tab then abcd would be output.
It needs to be the same as how seg comment works but im unsure of how to do it.
regards,
Brian
