Hello @Bluebellengineering
A default post for wire may work on this machine.  Do you happen to know the controller and version on this machine?
If it is a specialized controller, you may need to contact an Autodesk partner to build one for you at a cost.  Autodesk started charging for post processors about 4 years ago, so they are no longer included in the software costs.
You can check here for a reseller located in your area....Autodesk Services Marketplace
I work for a Canadian partner, so if you require anything, please do not hesitate to reach out.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
