kelbie.ockey
en respuesta a: caleberttt
Agreed with @ChristopherMarion's suggestion here.
I also assume that you are following this video, but in the case that you haven't seen this, it does a great job of walking through. If it's showing up, but importing wrong, I would assume that it's an issue with the actual setup. As Chris said though, if it's just flat now showing up, it's likely that the naming or location of the files is incorrect.
Kelbie Ockey
Sr. Implementation Consultant
