brian_p1
983 Vistas, 5 Respuestas
Post Variable Question
I'm wanting to write a post variable for calling sub program on siemens control, I only need the sub program name to be called how do I code it to return the wording entered in the post variable comment to be added to the nc code?
; 8 8MM ENDMILL
; 10 6MM SPOT
; 11 6MM CHAMFER GARR
; 12 12MM ENDMILL 3FL
; 14 2.8MM CBD
; 15 M3 ROLL TAP
; 18 4MM BALLNOSE
CYCLE800()
G00 G53 Z610 D0
D1
G00 G53 X-300. Y220.0
G00 G53 B0.0 C0.0
PROBE_TOP...............WORDING FROM POST VARIABLE
; SETUP1: BOSS ROUGH1 BOSS1 B0. C0.
G55 G17 G40 G71 G90
T="12MM ENDMILL 3FL"
<IF>[eq(<PVAR:CALL_SUB_PROGRAM>," ............. ")]<THEN>
