ChristopherMarion
en respuesta a: bhorstTGM48
@bhorstTGM48
If you have Solidworks installed, selecting Native in the import options may allow translation through Solidworks.
If not, you will most likely need to use Exchange for this translation.  You can check what versions of file types that are supported by the AMDEU by opening it in standalone.
  1. Go to Windows start
  2. Navigate to the AMDEU 2021 folder (Autodesk Manufacturing Data Exchange Utility 2021).
  3. Expland the folder
  4. Click the the AMDEU 2021 shortcut to open in standalone
  5. Go to HELP
  6. Go to Contents
  7. Go to Version & Entity Support
  8. Go to Solidworks
As you can see by this image.  It looks like it is not officially supported yet.  Probably in a update sometime soon.  However, those files still may translate into FeatureCAM without issue.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
