en respuesta a: Anonymous
I appreciate the help, but this is all useless to me if I cannot import DXF files into FeatureCam.... No matter what I do the software acts as if it's importing and when it's done there simply isn't anything there. For what it's worth here's a log after the import.
Exchange version:2020.0.0.9052
Input file: C:\Users\lcpeters\Desktop\TMTC.dxf
From format: AutoCAD
Output file: C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
To format: ddx
sdxOptProcessWireframe:true
sdxOptSendParasolidAsParasolid:true
dtpOptTrimmedSurfaceImport:true
sdxOptExplodeSolids:true
sdxTolMaxFileComplexity:10000000
a2dOptExtrudedCurvesAsSurfaces:false
Called Exchange to execute translation
Exchange translation was successful, importing from Exchange output
Log from Exchange:
Autodesk Manufacturing Data Exchange Utility 2020
Version: 2020.0.0.905203
Build Date: Tue Mar 19 12:48:16 GMT 2019
Status: Full Release
© Copyright 2019 Autodesk, Inc. All rights reserved.
Full Release
Unable to modify resource dtpOptTrimmedSurfaceImport with value true
The input file is C:\Users\lcpeters\Desktop\TMTC.dxf
The format of this file is AutoCAD
Resource file to be used is C:/Program Files/Autodesk/Manufacturing Data Exchange Utility 2020/sys/schemas/resources/AutoCAD.rsc
The following input resource values have been overridden :
sdxOptUseDuctEncoding:true
The output file is C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
Requested output format is ddx
Resource file to be used is C:/Program Files/Autodesk/Manufacturing Data Exchange Utility 2020/sys/schemas/resources/DDX.rsc
The following output resource values have been overridden :
sdxOptOutputUnits:inch
A voucher has been used for this translation
Reading file C:\Users\lcpeters\Desktop\TMTC.dxf
Writing the translation to C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
Product ID: Autodesk Manufacturing Data Exchange Utility2020.0.0.905203
Build: Build 03 Tue Mar 19 12:48:16 GMT 2019
License Tier used for translation: PREMIUM.
MEASUREMENT value for this file is set to 0 (Imperial).
LUNITS value for this file is set to Decimal (Undefined).
This file will be treated as if it were written in inches.
You can change this via the sdxOptInputFileUnits (set input file units) resource.
Ignoring empty drawing Layout1.
Ignoring empty drawing Layout2.
5 curve(s) were successfully translated.
1 annotation entity(s) were successfully translated.
.........%10%.........%20%.........%30%.........%40%.........%50%.........
%60%.........%70%.........%80%.........%90%.........%100%
Translation(s) complete
