ChristopherMarion
en respuesta a: Anonymous
@Anonymous
I've used the old interface (2017 and below) and the newer interface (2018 and above).  I can feel your pain in trying to navigate it and where to find things.  I suggest ditching the older seat and getting antiquated with the newer versions.  The ribbon interface trumps the toolbar based system, hands down in my opinion.
It will probably take you a few days to find where everything thing is.
Also, there is a way to work with the order interface in the newer versions.  If you are using FeatureCAM to program your equipment, you can do this.  But, if you are teaching students, I suggest just learning the new interface.
We can help here if you need it.  Autodesk never gave support to educational facilities, but you can get that here within the forum if you need it.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
