gabriele.esposito
en respuesta a: mcm1XYHXU
Hi @mcm1XYHXU , try to see this ARTICLE, after this test you can try to do another test follow this second ARTICLE.
About this second article if the problem is not solved, remember (for more security) to backup these files if you want delete from this folder, instead of renaming them as described in the article.
Gabriele Esposito
Sr Technical Support Specialist
Autodesk Make | Autodesk Knowledge Network | Autodesk Advanced Manufacturing | Autodesk Fusion 360
