05-26-2020
10:45 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-26-2020
10:45 AM
unlock AFR... options
I recently downloaded FeatureCAM 2020. when i select the "AFR..." drop down menu all of the options are shaded and i am unable to select any of them. how do i "unlock" these options?
05-26-2020
11:09 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-26-2020
11:09 AM
Hi.
AFR only works on solids, so if you have 2d geometry or surfaces, it will be dimmed out.
I hope that helps.
Chris Cole
Senior Solutions Engineer
05-26-2020
11:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-26-2020
11:59 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-26-2020
11:59 AM
Can you upload your file? Both the .fm and source CAD files would be the most helpful to rule out any issues with the data.
Kelbie Ockey
Sr. Implementation Consultant
05-27-2020
12:53 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-27-2020
12:53 AM
Hi @mcm1XYHXU , try to see this ARTICLE, after this test you can try to do another test follow this second ARTICLE.
About this second article if the problem is not solved, remember (for more security) to backup these files if you want delete from this folder, instead of renaming them as described in the article.
Gabriele Esposito
Sr Technical Support Specialist
Autodesk Make | Autodesk Knowledge Network | Autodesk Advanced Manufacturing | Autodesk Fusion 360
