ChristopherMarion
en respuesta a: Mueller-CNC
@Mueller-CNC
First, Z level isn't the only strategy that can handle undercuts.  It may be the only strategy that has that checkbox.
Unfortunately, Z level does not machine shallow surfaces because it slices the model in Z increments.  Great for steep regions.  You can turn on Optimize for that issue, but not with undercuts.
I suggest you use Flowline.  You do need to construct a surface for FeatureCAM to work from.  This surface is a reference surface.....not a machinable surface.
Take a look at the attached modified FM file.  If you need more guidance on how I achieved these results, let me know.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
