ChristopherMarion
en respuesta a: Anonymous
@Anonymous
Without looking at the file, I am not sure if you are milling or turning.
If you are turning, there is a "revolved surface boundary" option in the construct tab, within the curves group, under from surfaces menu.
If you are milling, you can create a planar surface intersecting where the section curve takes place.  you can then use the "Intersection" option within the same area mentioned above.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
