225 Vistas, 1 Respuesta
Geometry
Good morning, I have a contour geometry that i took off a model that was created in NX software, I imported the model as a STP file into featurecam. when i try to program a tool path that includes this contour Featurecam wont use it, when i select the contour the properties is greyed out, is it possible to slice the surface where the geometry came from in half and create my own contour from the slice? i even created a curve from the contour line and i couldnt program that. i cant send any file out which doesnt help. any ideas? i have a machine waiting.
ChristopherMarion
en respuesta a: Anonymous
@Anonymous
Without looking at the file, I am not sure if you are milling or turning.
If you are turning, there is a "revolved surface boundary" option in the construct tab, within the curves group, under from surfaces menu.
If you are milling, you can create a planar surface intersecting where the section curve takes place.  you can then use the "Intersection" option within the same area mentioned above.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
