- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello
It would be better to post an extra for each question.
The better overview and to recognize your question at all.
There are a lot of basic questions open to you, which you should work through step by step before your specific questions will come safely.
If I may say so. Sorry
I'll try to address a few things first, but 1001 open questions, I can't answer them all of a sudden
I will try to roughly point this out to you
see screenshots
1.
in short, you should generally adjust your machining configuration first.
This goes on for a long time (weeks, step by step) until you have adapted all of them for you, according to your technology and preference.
Basically everyone works and hires for you.
This saves a lot of routine work, it is worth the effort to save yourself work every day.
Then fine tuning again and again.
2nd
I pre-drilled the holes without roughing and just finished with spiral finishing, especially in the strategy of activating the feature.
3rd
You have contoured with 0 material measurement,
are two options.
Specify material dimensions with 0.5
or
Create profile of contour offset of 0.5 and this profile
or use any profile in the feature as a blank profile
you can specify any blank shape, including volume, etc.
4th
How do you want to dive in?
Where do you want to dive?
5.
what tools and size do you want to use?
Would you like to rough and finish with one or more tools?
Then choose technology
And basic setting in machining configuration, see 1.
6.
If you need training, please organize your support contract through your contract.
7.
Have your * .cnc postprocessor customized at support.
8th.
etc.
1001.
Here you have reached the basics for feature cam.
Please work through it first, step by step
1002.
Here you can start with your own questions
Please open a new post for each, thank you.
Sorry, but in the short time and the many obvious basic points, I can point this out to you first.
If something helped you, please like and mark it as a solution.
Good luck.
And stay healthy.
Sincerely yours
Mathias Beyer
Project:
Please number projects by and not with fm1 etc.
Hallo
Es wäre besser für jede Frage ein extra Post auf zu machen.
Der besseren Übersicht und überhaupt deine Frage zu erkennen.
Bei dir sind sehr viele grundlegende Fragen offen, die du Schritt für Schritt erst abarbeiten solltest bevor deine eigendlichen Fragen sicher kommen werden.
Wenn ich das so mal sagen darf. Sorry
Ich versuche erst mal paar Dinge anzusprechen, aber 1001 offene Fragen, die kann ich dir hier mit einmal nicht beantworten
folgend versuche ich dich darauf grob hin zu weisen
siehe jeweils Screenshots
1.
kurz gesagt, zuerst solltest du im allgemeinen deine Bearbeitungskonfiguration anpassen.
Das geht über eine längere Zeit (Wochen, Schritt für Schritt) bis du die alle für dich angepassgt hast, nach deiner Technologie und Vorliebe.
Grundlegend erst mal alle durch arbeiten und einstellen für dich.
Damit spart man sich Routinearbeiten enorm, die Mühe ist es wert, sich täglich damit Arbeit zu sparen.
Dann immer wieder Feintuning.
2.
die Bohrungen habe ich vorgebohrt ohne Schruppen und nur geschlichtet mit Spiralschlichten, extra in Strategie vom Feature zu aktivieren.
3.
Kontur hast du mit 0 Materialaufmass gemacht,
gibt zwei Möglichkeiten.
Materialaufmass mit 0.5 angeben
oder
Profil von Kontur Offset von 0.5 erstellen und dieses Profil
oder ein beliebiges Profil im Feature als Rohteilprofil verwenden
da kann man beliebige Rohteilformen vorgeben auch Volumen usw.
4.
Wie möchtest du eintauchen?
Wo möchtest du eintauchen?
5.
welche Werkzeuge und Größe möchtest du verwenden?
Möchtest du mit einem oder mehreren Werkzeugen Schruppen und schlichten?
Technologie danach wählen
Und Grundeinstellung in Bearbeitungskonfiguration, siehe 1.
6.
Falls du Schulung brauchst, bitte über dein Vertrag beim Support organisieren.
7.
Dein *.cnc Postprozessor beim Support anpassen lassen.
8.
usw.
1001.
Hier hast die Grundlagen für Featurecam erreicht.
Arbeite die bitte erst mal ab, Schritt für Schritt
1002.
Hier geht es mit deinen eigenlichen Fragen los
Mach dafür bitte jeweils ein neuen Post auf, Danke.
Sorry, aber in der Kürze der Zeit und die vielen offensichlichen grundlegenden Punkte, kann ich dich erst einmal darauf hinweisen.
Falls dir was geholfen hat bitte like und als Lösung markieren.
Viel Erfolg wünsche ich dir.
Und bleib gesund.
Mit freundlichen Grüßen
Mathias Beyer
Projekt:
Projekte bitte durch nummerieren und nicht mit fm1 usw.
