1003 Vistas, 13 Respuestas
Noob - - - >help
Hello I'm looking for some help regarding feature cam. Sorry in advance for the text I am French and I use Google trad.
I start in CNC machining and I just asked for your help regarding featurecam. I am more or less starting to take it in hand however I have a problem of choice of feature. I can not create a contour of my piece corresponding only to the shape of it without all my rough is completely machined until arriving at the final shape of my piece. What feature / technique do you use? I also have a problem on the creation of my gcodes: from what I understood featurecam puts two codes which conflict on the same line (N7065 G0 G91 G28 Z0 M09) and those on all the generated gcodes. I have to delete G0 so that mach3 can read the g-code but that it affects the machining? thank you in advance
