gregorANU4T
579 Vistas, 3 Respuestas
No way to access the Edit SCL Code dialog in 2020?
The Edit SCL Code dialog was a tool that I used occasionally to subdivide curves, specifically to generate plunge points along a path, as per this technical note.
The option to enable it still exists in the hidden menu, but the UI has no way to access it. Turning off the ribbon doesn't help, the option doesn't show up in the edit menu.
Am I missing something, or has this useful tool been abandoned?
