matthew_zarycka
501 Vistas, 4 Respuestas
Un docking operation list
 Is is possible to UN-dock the operation list and move it to another screen?  I have two monitors at my work station, but only utilize one when programming.
Matt
kelbie.ockey
en respuesta a: matthew_zarycka
Unfortunately, it is not. Can only be expanded, resized, and collapsed.
Kelbie Ockey
Sr. Implementation Consultant
en respuesta a: kelbie.ockey
Ideas suggestion
Hi there.
I have to hook up here.
I also imagine this requirement.
But with a different kind of functionality.
My idea is this:
and if you're so nice, put it on
Autodesk development team as an idea suggestion.
Let's see what they say about it?
I would appreciate a short answer.
Idea:
see also screenshot, how it is possible with Windows 10 in the taskbar settings, so I imagine it in Featurecam with all the ribbons etc.
So you would have the whole screen available and if you point the mouse at the right, left and top edge, the respective ribbon or etc. will be shown.
If you drag the mouse away from the bar, the bar is hidden again.
The way I do it with the Windows taskbar, see screenshot.
That would be a very convenient solution for increasing functionality.
I personally wish that every day, it would be a dream.
Hope dies last.
I think it's the smarter solution to get the most out of the screen.
Would be a quantum leap!
I am happy to answer any further questions if you have any questions.
Sorry for my english.
Sincerely yours
Mathias Beyer
Ideen Vorschlag
Hallo.
Hier muß ich mich einklinken.
Diese Anforderung stelle ich mir auch vor.
Doch mit einer anderen Art der Funktionalität.
Meine Idee ist folgende:
und wenn du so nett bis, lege es doch dem
Entwicklerteam von Autodesk als Ideen Vorschlag vor.
Mal sehen was sie dazu sagen?
Ich würde mich über eine kurze Antwort freuen.
Idee:
siehe auch Screenshot, wie es bei Windows 10 bei der Taskleisten Einstellungen möglich ist, so stelle ich mir es in Featurecam mit allen Menübänder etc. vor.
Somit hätte man den ganzen Bildschirm zur Verfügung und wenn man mit der Maus an den rechten, linken und oberen Rand zeigt, wird das jeweilige Menüband oder etc. eingeblendet.
Zieht man die Maus von der Leiste weg, wird die Leiste wieder ausgeblendet.
So wie ich es mit der Windows Taskleiste mache, siehe Screenshot.
Das wäre eine sehr komfortable Lösung für die Steigerung der Funktionalität.
Ich persönlich wünsche mir das jeden Tag, es wäre ein Traum.
Die Hoffnug stirbt zu letzt.
Finde ich als die intelligentere Lösung, um den Bildschirm am optimalsten nutzen zu können.
Wäre ein Quantensprung !
Ich stehe für weitere Fragen gerne zur Verfügung, wenn noch Fragen offen sind.
sorry für mein englisch.
Mit freundlichen Grüßen
Mathias Beyer
If these three bars automatically hide (see screenshot), you get the double usable screen.
If you want to select a function on the bars, you move the mouse to this point anyway and the bar is shown.
Or you don't need to have them displayed when working with keyboard combinations.
Sincerely yours
Mathias Beyer
Wenn sich diese drei Leisten automatisch ausblenden ( siehe Screenshot ), bekommt man den doppelt nutzbaren Bildschirm.
Wenn man auf den Leisten eine Funktion wählen möchte, geht man mit der Maus sowieso auf diese Stelle und die Leiste wird eingeblendet.
Oder man braucht sie nicht eingeblendet haben, wenn man mit Tastatur Kombinationen arbeitet.
Mathias Beyer
lee.hillman
Hi
Just a suggestion and only because I've seen this on another customers setup and I have to be honest it seemed to work quite well
If the two monitors are set to extend ...... Make the Featurecam window extra wide
This way the main graphics area can be displayed as large as possible on the left hand screen or Monitor 1 for example and just the Operations list is visible on monitor 2 or the right hand screen.
Hope that makes sense ?
