kelbie.ockey
en respuesta a: DWhiteley
The process is a little different in FeatureCAM. Instead of chaining edges, you can select horizontal or vertical faces to define the boundary of any feature, including a side feature. Additionally, there are a couple of additional options with feature recognition to 'chain' profiles in a more customized sense.
Check out this article showing the use of the 'Select side surfaces' method. This method happens to be my personal preference when using IFR, and should help you out with your situation. If you have a specific part and a specific feature you would like to recognize, I would be happy to throw together a short video explaining.
Kelbie Ockey
Sr. Implementation Consultant
