1234 Vistas, 12 Respuestas
02-15-2017
11:21 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-15-2017
11:21 PM
Hello everyone.
I have problem with uncut surface by using cutters with radius.
Namely. I choose surface (here radius) to milling and it comes (cutter) to surface boundary and stops. It leaves uncut place which has radius of cutter. If cutter had no radius on the corner it would be correct, with no uncut place.
I'm looking for answer how exceed boundary with cutter (with radial corner).
I've tried parline and add bottom milling (add new strategy) and the same.
You can see on the second side is correct (bigger radius)...
Thanks for help.
I put some pics.
¡Resuelto! Ir a solución.
