- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Sorry to hear of the loss of another skilled man.
The lack of response maybe that there is a separate forum for theses software packages although technically they now come under the fusion umbrella. So to answer
1- if most of your current programs are in PartMaker then stick with it for now. You probably have working posts and they are a paid item in all three of those softwares. PartMaker is super easy to learn and use. I say for now as i think we can all see autodesk's direction of travel and i'm sure all of PartMakers functionality will appear in Fusion at a later date.
2- Simulation files, talk to your reseller if you can't find them, the come with your licenced post processor .MCH file.
3- They are not directly compatable, however PartMaker can import PowerMill tool paths for complex milling and FeatureCam can output G-Code from some PartMaker posts (they were the same software before Autodesk or even Delcam days).
Hope that helps or somebody chips in with their thoughts too.
