852 Vistas, 10 Respuestas
Facing Featurecam Milling
When programming with a solid block, in a face figure, the tool is very much in empty parts, it would be possible to make a circular programming, the tool would follow the material of the block that really exists.
Attached project, thank you very much.
en respuesta a: Anonymous
hi,
to do this you should load Spiral_Face Macro
have a nice day!
chris.coleQDYFL
RichardLagace is right. Here's a video that explains what it is and how to use it.
https://www.youtube.com/watch?v=8rPrp-K9Lws
Chris Cole
Senior Solutions Engineer
en respuesta a: chris.coleQDYFL
Thank you very much, the solution is of great value.
Hug.
Muppett1
Thanks guys, I now have the spiral face add in loaded as well!
en respuesta a: Muppett1
I also loaded the macro, very useful.
Hug
Very helpful I can't wait to try it. I will be loading it today.
I also like to use the Spiral Face Macro.
Here are a few tips with which attributes you should play.
see screenshots.
Sincerely yours
Mathias Beyer
Ich verwende das Spiral Face Macro auch gerne.
Hier ein paar Tips mit welchen Attributen ihr spielen solltet.
siehe Screenshots.
Mit freundlichen Grüßen
Mathias Beyer
Thank you very much for the solution.
Hug.
Muppett1
  • I haven't tried it but once very quickly, but is there a way to reduce the polyline programming into arcs?  The small face example I tried created a large NC file with XY moves.  Thank you.
Steve
The question has also arisen for me.
I cannot answer you.
Sincerely yours
Mathias Beyer
Die Frage hat sich mir auch gestellt.
Ich kann sie dir nicht beantworten.
Mathias Beyer
