01-04-2020
05:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-04-2020
05:41 AM
Gabriele, in the "Z Level Example" toolpath, did you draw a circle around each of the holes and select that as your boundary?
Yes correct.
You have right when you said that Z level is the toolpath most used, the only limit for this strategy are the shallow areas, in this case having to ensure a constant Z-step will increase laterally on these shallow.
You can still improve by using "Scallop stepover" and entering a Min. Z increment value, see the image.
Regards
Gabriele Esposito
Sr Technical Support Specialist
Autodesk Make | Autodesk Knowledge Network | Autodesk Advanced Manufacturing | Autodesk Fusion 360
