kgueorguiev
634 Vistas, 4 Respuestas
Surface Milling Z-Level Roughing not extending to the correct lines
I am trying to 3D surface mill the radius around the part, but my tool isn't going to the outer edges of the geometry. If you run a 3D simulation, you can see that my machined radius does not extent to the outer edge of the radius on the model (see screenshots). How do I "expand" my toolpath to the correct lines?
